Quote from Arctic Cat:
DO NOT REMOVE THE WHITE SEALING RING!!!!!!!!!!!!!!!!!!!! YOU WILL HAVE
BURN DOWNS AND FUEL SYSTEM RELATED ISSUES LIKE PLUGGED INJECTOR SCREENS.
Rob, The valves DO NOT, cause burn downs. I am not sure what you are seeing
but I will check with some guys here. We have had some burn downs from
cooling system issues. They are normally the mag side. I don't believe I
have seen a crank failure at all on the 700s and I do not believe I have
seen a seizure not related to a cooling system issue. They have all been
over heat issues. Please do not support taking the valve part of the smart
valve out. It will cause serious issues for people. It sounds like a knee
jerk fix and its not the right way to go. If the valve was put in and it
was put in flat then there shouldn't be any issues. If the dealer installed
it on its side even at a 45 degree angle to the bottom of the tank then you
will have a problem. They must run flat.[/b]
