After I looked at all the different microfiches from 00'-03' every EFI sled has the same style smart valves except the F7. It seems they must have changed from the traditional "T" fitting which branches off the main line into two seperate closed ended valves, to the F7 style which has an inline smart valve connected to a closed end smart valve. It looks like they had to do it that way because of the different tank configuration of the F7. All the part numbers are the same for the closed ended smart valves. It's definetly part 15 on the fuel pump assembly pic(part # 1670-460). This is the only different smart valve out of them all. :blink:
