1 - 2 of 2 Posts
guy, if you are installing your own smart valves for the update, the torque spec. in the instructions is incorrect-check with your dealer-i believe that it is supposed to be 6.0-7.5 ftlbs not 60-75 but ask to be sure
That is correct. For this update you take the whole assembly out of the tank so therefor you have to disconntect the fuel line going to the rail from the gas tank. That hose clamp there is what needs to be torqued to 5-6ft. lbs. Just make it snug and you will be all set.
1 - 2 of 2 Posts
