1 - 11 of 11 Posts
about 50 percent of the time when I punch it, it doesn't respond and the other half of the time it responds great.. What is the problem.. to me it sounds like bogging and then will rip once it catches up and burns off.. I also have a BMP Can and people tell me it is the can.. Should I get rid of the can?
Sounds like valves are not operating properly. Have you checked the cable adjustment both have to be exactly the same length or the valves won't open motor cycles 3 times if cables are off the motor will not open valves. I think the measurement is 34.5mm. My friends 03 F7 was doing the same thing adjusted the cables and found a cable shielding loose runs like nails every time now.
These machines are coming from the factory running too rich (35:1) when it should be somewhere around 50:1. You probably need to have it leaned out. There is a thread that explains how to check your fuel to oil ratio. If too rich there are instructions on how to change it or have your dealer lean it out for you. There are numerous people on this forum that have done this and the bog is eliminated. Good luck!
These machines are coming from the factory running too rich (35:1) when it should be somewhere around 50:1. You probably need to have it leaned out. There is a thread that explains how to check your fuel to oil ratio. If too rich there are instructions on how to change it or have your dealer lean it out for you. There are numerous people on this forum that have done this and the bog is eliminated. Good luck![/b]
Thanks Guys..
Can anyone help me with a problem, 06 Crossfire 7. Bought last year, 2800 miles, ran tops, awesome I must say! Love the sled but after getting the exhaust ports cleaned plus 600 miles later, fuel milage is terrible. Dont have near the power, bottom or top end. Also no matter what the weather conditions were last year, as shutting off machine not once did it ever backfire. Now this has happened to frequently.
can you guide me in the direction of these instructions?
not familiar with crossfires, but just to throw this out there. if a sled is efi, and you have a can, you only have like a 95% chance that it will work right. i read this on speedwerx's sight last year. again, just throwing that out there.
1 - 11 of 11 Posts
