1 - 20 of 53 Posts
2012 Pro R Switchback
Attempting to pull the secondary off the 92 340 and it's rusted seized on the driveshaft. Tried a few good whacks with rubber hammer but to no avail. Any suggestions or experience with getting one of these off a splined shaft?
Discussion Starter #3
i think i may try putting it on it's side for a few days with some PB blaster. Will have to see if i'm able to get this shaft out without any damage to other components
Take chaincase apart. Take top gear off, bearing behind clutch and slide clutch with shaft attached out as a unit.
Then you can work at it.
Discussion Starter #5
no chain case on this one unfortunately as it's direct drive....that's the issue with this one. 91/92 were DD.
Discussion Starter #8
fill me in on the puller, first time i've ever heard of having to use a puller to remove a secondary clutch on a polaris. Was going to tip it on it's side and soak with PB blaster after i take the carbs off
I doubt it even applies. Yours sounds really stuck. My wifes fusion had the secondary stuck on the shaft. I wrapped a ratchet strap around the back of the clutch. Wrapped the ends of the straps around my hands. With slack in the straps up to my hands I started to yank the crap out with my arms and body. I almost gave up until I noticed it started to actually move. Once off I had to clean the splines on the shaft and in the secondary one by one for it to float again.
The 90’s should still have a keyed shaft. Before putting a lot of effort getting it off, look to see if the key is present. If it’s not present the clutch is fused to the shaft.
1 - 20 of 53 Posts
