I did a forum search for this and couldn't find anything for the standard model. My question is:
How do you remove the seat on 2007 F-Series Standard Models?
The users manual describes seat removal for the snopro and lxr models but does not describe standard models accurately.
According to the users manual it says to remove a small screw under the right front corner of the seat then pull up on the seat adjustment lever to completly remove the seat.
This does not apply to standard models and I could not find a screw anywhere that was holding the seat. I tried to pull up on the seat by grasping the back portion of the seat. The seat bends and does not release, I'm worried I'm going to wreck something if I pull on it too far.
Help? Please.
Thanks,
Neil
WRONG!!! In the front of the seat if you bend it upwards you have a stop screw on the right side you can slide the seat in the top position and then it comes right off!!!
Catmasterf7, this applies to models with the infinate rider positioning. I have a standard model. There is no stop screw on the right side under the seat.
Thanks,
Neil
