1 - 7 of 7 Posts
2014 XF800 137
Took off Y pipe off today and noticed this, is this bad??
Too hard to see, but that doesnt look like a scuff, roll it down to where you can see the rings and top of piston and cylinder walls. The skirts look pretty good!
thats not a good thing!!! I would pull the head and cylinder iff you know what you are doing or pring it to the dealer. it will only get worse and iff it tis an oil issue most likely the wristpin is jammed pretty good
once the head and cylinder are off that will give you a better idea. I was just saying if it was an oil issue it takes a little longer to get the piston off. most likely its an coolant issue, the ones that I have seen with the center scuffed was from cold siesure
1 - 7 of 7 Posts
