did u get the full billet head? or just the domes for the stock head? what did u use to plug your bypass line?[/b]
Got the full billet cover and heads. 13:1 CR domes. A buddy of mine made a brass plug for the bypass hose.
RKTek sent me a cover where the two front head bolt holes were a machine tapered to use "O" rings under the head bolts
which I didn't get. Once I got "O" rings to fit(I used Artic Cat head bolt "O" rings), everything was all set.
With my compression guage I am getting 130 psi compression(cold engine).
Definately sounds way snappier on the stand.
Polaris9500,
Did you retorque your head bolts after you installed your head?
