I have the lever kit and the proper cover from my 1997 600 triple.Not sure of the gearing you need but I have some extra gears also .Still have the stock gearing from my 03 /900 ZR also.Most reversekits for the old style bodies will work,excluding the lever kits and in some cases the outside cover is different as the lever kit is applied to the front of some and the back on other covers.That is why I have the older cover here because I have a 2002 ZRT now and the cover is different.Guess what I am trying to say is that the shifting arm on the bottom of the cover is on the front of some and on the back of others otherwise its the same cover.So if you can pick up the inner components from someone else I have everything else needed.
