D
duke1n
·Guest
Since I already run pre-mix in my other sled I am wanting to remove the oil injection system from my F7. Does anyone know if there are blocker plates available? What is used on the 440s? Thanks
Consider the effects fuel has in your float bowl over the summer months. All gummed up and green if not looked after properly. Any oil breaks down over time and also leaves deposits. This is only amplified during an engine hot soak. Deposits will form on the injector pintle over time. Even the additives in fuel cause deposits to form on injectors. The filter screen at the top of the injector is very fine and any additives to the fuel can plug this also up.Originally posted by duke1n@Dec 8 2002, 10:21 AM
I don't think having oil in the fuel is going to harm the injectors? Why would it? I also don't think think that having 3% of your fuel being replaced by oil is going to significantly alter it's viscocity to the point it would make any difference.
