21 - 28 of 28 Posts
Since I have owned several Tcats and a turbo, I can tell you that in a drag race on a good surface, an old Tcat would beat a stock 1100 in a drag race. If I remember correctly, at the old American Snowmobiler shootout in 1998, a box stock Tcat posted 110mph in the quarter mile. The Tcat would easily get past 120 on radar and on a good day hit 125. A stock 1100 cannot do that.
The reason the old old Tcat wins is twofold: # 1 - less rolling resistance on the chassis. # 2 - It weighed about 85lbs less.
This why everyone boosts the 1100. With a 240 tune ( or more) it is a different sled. Once boosted, it is a much quicker and faster sled. I love mine except for dealing with the undressing the sled every time I want to work on it.
I own one of each , on the 1100 , using a evo intake and Zeus fittings I can have my hood off in a matter of minutes. Putting it back together takes a little bit longer. Those older T-Cats sat a lot lower also.
My take; A (properly prepped) trail ridden stock 1100 Turbo is only slow compared compared to a tuned Turbo or a stock/tuned 998. I rode my '12 Turbo mostly stock (exhaust) for a year and it was far from slow. I was warned by my "go-to" Turbo guy that if you tune it you have went to the Dark Side. Yep, sure did. I run a 2.5" SanDale with a 2stg (e/PT) TD flash, and run 98% of the time on ECO. At 225Hp, its very enjoyable.
I must have a good running 1100 in stock form because I beat my buddies 998 every time and we are pretty much same size. Granted both are stock.
Just comes down to traction, how they are tuned (in stock motor form) and the pre 998's took more time to spool up without a stutter button so 2-strokes could leave the past version turbos at the line. Lots of lightweight chassis efficient F-7's embarrass big triples and the first version turbos when they came out in 500 feet. Once you jump off the line and are out ahead it takes a lot of HP/ground speed to get by someone. All sleds both 2-stroke and 4-stroke have come a long ways all to the buyers benefit.
21 - 28 of 28 Posts
