1 - 10 of 10 Posts
Are you talking about a performance reflash, or ???
As far as I know, newer flash code from Polaris is not really beneficial. However, if you're talking about getting a "tune" done to increase performance, then Precision Sports is the place. They have their "2012" flash that I've heard is fantastic. Looking to get mine done at some point.
Thank you
Don't know if still active...but the MY06/07 had a recall to reflash ecm to MY08 by dealer. There were 5or6 recalls on that sled..did you get them done? B
Sent from my SAMSUNG-SM-G930A using Tapatalk
The most important tweaks would be notching the jack shaft shield..so the temp sensor wires don't get damaged and adding additional ground wire at the ecu... Additional items..vacuum leak check and wire loom relocates.
1 - 10 of 10 Posts
