I drop the back of the suspension to replace my shock by removing the tension and the front holders on the springs and just the two rear bolts. Now I am re-installing if I do it in reverse line up the two rear bolts will I have problems putting the front spring holders in? All help and any tricks is greatly appreciated.
Take the tension off the rear springs and it will bolt right back in. Also always put the front bolts in first.
Take the tension off the rear springs and it will bolt right back in. Also always put the front bolts in first.[/b]
I have the tension on the lowest setting and only the rear two bolts out all I needed to remove the rear shock the only thing I am wondering after I put the two bolts back in the rear will I be able to align the springs and cups up front by hand? Please Help.
Yes, keep the spring blocks off and let the springs hang down until all four bolts are in -- this makes it a lot easier to align the back bolts. After its bolted in then put your spring blocks in. You have to be EXTREMELY careful -- just have the bolt through the block and then place it in the rail.
a little trick ive found is to leave the bushings out until you have the front bolts in and then tap the bushings in with a hammer
