22 850 xc 129, can i get the rear shock off without pulling the skid?
Yes. To pull the FTS out you have to aline the bottom bolt with the clearance hole of the front idler wheels which is not bad. Then you need to realign it when having the shock/spring partially compress to realign the bolt to reinstall it. Much easier to just pull the skid and unbolt the limiter straps to install the FTS.Rick, maybe I’m missing a step in my advanced age … but the last time I put a coupled suspension shock back in (2022 VR1 137) I wished like hell I’d pulled the skid first; taking the shocks out was easy enough but trying to sync up the front and rear arm compression to line up the bolts to put them
back in was a bitch, with the skid in the sled.
What’d I miss?
yes i will post a picture of it if i can figure out how to post pic's here? seems real confusing to me.TY so much! Collapsing the front arm without removing the skid was the missing piece. My method was the same… except remove the skid so I could flip the skid upside down and use a boot on the front arm, use body weight to compress and align. Then stand on it again to bolt it back together.
Let me guess, the very simple tool works on the same principle as a c clamp?
