This is quoted from somewhere, I believe this site a while ago.
"I hope I am wrong, but have any of you tried putting grease into the zerks that are near the front AWS upper shock mounts (in the what I will call 'fender well area)? The left one filled up nicely, and when full starts to seep grease out around the inner bellcrank arm and under the hood at the top of the steering bellcrank (black cap on it). The right side had no resistance when I was pumping grease into it . I just kept pumping and pumping only to notice that the inside of the bulkhead was filling up with grease, right near where the clear plastic tube that comes out of the ECU runs down to where you can no longer see where it goes. I sure hope that there is not a improper weld on where this inner idler bellcrank is welded to the bulkhead!"
I had this exact same problem last night when I went to grease my standard F7. Has anyone else had this problem? If you haven't checked it out yet, you might want to. Seems to me it's a rather important area that really could use the grease! -- Roy
