1 - 7 of 7 Posts
I was wondering what everyone does to prepare thier sleds for the time when we don't have snow. Should I get all the fluids out or what? I usually siphon most of the gas and then run the rest out of it. Should I also drain oil and coolant or what. Tell me every step...
i ------------------->
top off the tank
add fuel stabilizer
100:1 pre mix in the tank (keeps seals nice)
run the motor till the stabilized/pre-mixed fuel gets into the carbs
remove airbox and spray fogging oil into carbs till motor stalls or chugs
reinstall airbox
remove plugs and put 1 tablespoon of oil in each cyl and pull over a couple of times
spray everything with silicone or a light oil including all suspension parts
clean and wax
put in the trailer until the ground is white again
oh, and i plug the exhaust pipe too... after my uncles polaris wouldn't run one year, we found mice had gotten in and made a nest in the exhaust.. had about 5 lbs of dog food stuck in the pipe...lmao
Hey f5snopro, why don't you put fogging oil in the cylinders also. I do the exact same things you do, but always spray the fogging oil in the jugs instead of putting oil like you mentioned. Just wondering what your reasoning is. I am all for doing the best for taking care of my sled.
1 - 7 of 7 Posts
