1 - 16 of 16 Posts
I am pulling the heads off my '05 snopro and they do not want to come off :augen41: any suggestions? All ideas or tricks would be welcomed. Thanks :banana:
I had the same damn problem.. you know what it was? there is a bolt inside where the coolant line hook into. I hope that is it, comes right off then, lol.
JJB,
Are they both giving you trouble..?? If you have the hex bolt removed that Firecat Pilot mentioned, try tapping on them lightly with a rubber mallet while pulling up on them....
-John
Did not know about the hex bolt :banghead: thanks guys!! i will check it tonight ....I am finally getting going on this conversion it's been a crazy summer work wise John which heat exchanger did you use in your sled? I have been looking at a couple of differant ones and have not had a lot of time to read up on HCS to see what you guys have been up to with your conversions :HCS_rules: thanks again!!
<div align="right">index.php?act=findpost&pid=863884
JJB,
I have decided to go with the guy in NY's under tunnel cooler set-up. I called him today and left a message to order it.
-John
Pic of set-up..........
John i sent my seat to the guys in NY last week i am getting the tank, heat ex, and they are doing my heads also i am trying to get it together by mid Oct. and run in some grass drags :beerchug:
Originally posted by JLeosnow@Sep 7 2005, 07:38 PM
JJB,
-John
Are you going to have problems with the track/studs contacting that setup? Isn't that area on both sides of the center rib used for track/stud clearance? Even if it doesn't hit the heat exchanger itself, I am pretty sure that the track hits the center rib. I don't know how the track is going to like a big void in that rib when it decides to hit it. Of course you could run the track soo tight you don't have to worry about it, I guess. Just curious, not bashing. It looks like a neat remedy for cooling issues.
When converting heads to be used for trail use, do they shave them down ? Or are the trail heads thicker than the race heads
Originally posted by SickNasty04F6@Oct 12 2005, 06:09 PM
where are you guys getting your heads cut??
<div align="right">index.php?act=findpost&pid=925360
SickNasty04F6,
The reason people are changed/machining the stock heads is that the compression needs to be lowered from stock form on the 04/05 440 SnoPro's to run pump(92-93 octane) fuel instead of 110 octane race fuel which is what the stock heads are designed for.
-John
<div align="right">index.php?act=findpost&pid=936391
snoprochris16,
When machining the stock 04/05 440 SnoPro head(s) for pump fuel it is the "dome" area of the head needs to be machined/opened up to lower the compression ratio.
-John
<div align="right">index.php?act=findpost&pid=924818
Good question, anyone have any insite?
Discussion Starter · #14 ·
the track on this sled is a 1.7 lug it does not hit the center rib,the rib is not even a half inch this heat ex. works as a tunnel protecter it will have a hyfax running down the center of it
Originally posted by JLeosnow@Oct 17 2005, 08:57 PM
SickNasty04F6,
-John
<div align="right">index.php?act=findpost&pid=936426
I know :doh: !!! re read my original post.........i asked where ure getting them cut...i have 2 440s....04 and an 05
<div align="right">index.php?act=findpost&pid=996629
SickNasty04F6,
Oops, sorry about that. You are correct, I read it as"WHY are you guys getting your heads cut...... :frech32: Sorry 'bout that!! :div20:
-John
1 - 16 of 16 Posts
