1 - 2 of 2 Posts
Well I stated my sled today after I did some track adjustments and greast all my fittings. Afterwords I fired it up to check if the track was running even on both sides, since I had the under caridge out this summer to replace some parts. After running it for about 10 min and A few throtle punches to get the RPM's up, it was idling fine at about 1600- 1700 RPM's, so I shut her down satsfied. That's when I noticed a few drops of chain oil drip from under the sled. I slid my little finger in where the driveshat goes in to the chain case and came out with an oily finger. I took off the dropcase cover located on the thotle side, everything look's fine, bolts are all tight?? What's the problem?? I have no clue. Can someone help me out???
Thanx
Bullet :help:
there are 2 possibilities
-the o ring in your driveshaft housing is bad
-the seals from the bearing are busted??
Hope this helps
1 - 2 of 2 Posts
