I cleaned the power valves because they were causing problems. When I tested them in the garage, they didn't move. I didn't get any codes in the engine light.
Ideas???
BTW this site saved me a ride because I knew that the 6 flashes meant power valves. I turned them manually and rode the rest of the day.
Rob you are the best!!!, too bad I got my check back...
After reading what others have to say, there seems to be a difference between how the F5 and F7 servos work.
My F5 SnoPro will cycle through the clean-up after the engine warms-up and only after you pick-up the rpm's to about 2500 (an electrical thing). At 6500 rpm, the servo motor opens or lifts the power valves. You should hear and definately should feel the difference while riding!
