1 - 8 of 8 Posts
D
Guest
I know this is been beat to death...
Going over the sled tonight. What is the procedure for checking and adjusting PV cables? Thanks
roll the cables off the servo and they should measure between 1.423-1.501 in. is the quick answer
D
Guest
Discussion Starter #7
Thx! They were 1.5" so I left them alone. My throttle cable had developed nearly 3/16" play so tightened that up.
Should tell you, GLS said that the exact lenghts(36-38mm) are not as critical as MAKING SURE YOU GET BOTH CABLES THE SAME LENGHT
1 - 8 of 8 Posts
