Customer wants aftermarket grips and thumb warmer put on his wife's sled. Stock grips work fine in my opinion, but he brings me an aftermarket kit with this cute little control panel and hookups for two other accesories. Grips swapped no problem. Had to clean up the inside of the throttle flipper with a Dremel so the new thumb warmer would sit flat. There are only two wires that require hooked up to run this things. A regulated positive 12 volts and a ground. A ground I can pull from anywhere. It's the 12V+ I'm having trouble finding. The customer wants the grips to only have power when the key is on, which makes sense.
I looked at the original harness that the factory Cat grips use and thought it would make the most sense to take power from there seen as it already functions in the desired manner. There is a four wire harness that the original grips used. It has two browns ( I assume are grounds on an Arctic Cat ) and two yellows. One yellow may be a tad lighter than the other but maybe it's just my eyes. I can't figure out for the life of me why I can't get power out of that location. It came from there before. All the other electrical works like the headlight dimmer and kill switch. The only place I can find power when the key is on is the fuel pump, and there's no way in f*ck I'm tapping into that. I also don't want to mess up the stator or anything so I thought I would quit while I was ahead.
Can anyone help me out? It's probably staring me in the face. Maybe a jumper or something? I don't know if it has anything to do with the EFI but like I said before, better ask and see.
