I'm well aware of everything costing an arm and a leg these days but a gallon of Polaris VES Extreme is now at $70+tax. Ofta.
Where are these specs listed lol. I think Lube Tech is the only one that know the exact specs.Most sled oils out there meet or exceed OEM oil specs.
The chemist😂🤣Where are these specs listed lol. I think Lube Tech is the only one that know the exact specs.
The C-Tec oil is very thin so if I had a C-tec I would run it for sure.I understand that the Mfgs. and dealers tell and want you to run their oil but it does seems that almost everybody I ask says that it’s important to run CTEC Oil in CTECS….no ifs ands or buts…is this true? 🤷🏻
I’ll respond to the original post and say this... I really understand the manufacturers recommend that you use the oil they sell / label for good reasons , like it’s engineered for there motors let say, also to keep the uneducated or potentially owners buying something NOT meeting the requirements so you would think in order to not only protect the consumer but to also protect the manufacturers against undo claims in the warranty area they would make this SO important component to the machine very affordable.. I don’t want to here about what ya spent on your new sled and won’t spend 70$ a gallon on oil lecture. It should not cost that much... it’s an easy buck for the OEMs to charge so much for it. Polaris really does a neat little video on how the VES extreme is purposely engineered for the 850... so make it affordable so ya know people will be using it!I'm well aware of everything costing an arm and a leg these days but a gallon of Polaris VES Extreme is now at $70+tax. Ofta.
On the oil bottles.."meets and exceeds" if in doubt contact the oil manufactures like we did, here call this number on just 1 non- oem oil: 1 800 242 0489Where are these specs listed lol. I think Lube Tech is the only one that know the exact specs.
Interceptor? I wouldn't run it in my weed eater.Just run Amsoil Interceptor instead of Extreme.
I think if more sled owners saw what that stuff does to the engines lower components, they choose another oil fast. Interceptor has very poor rust protection if you don't fog the engine.Interceptor? I wouldn't run it in my weed eater.
Correct, if the OEM said that, then they would have to provide free oil, so they do not say that for obvious reasons.On the oil bottles.."meets and exceeds" if in doubt contact the oil manufactures like we did, here call this number on just 1 non- oem oil: 1 800 242 0489
The US Government Magnuson/Moss act states very clearly that if any manufacture states you cannot use a non-OEM product which states on the non-OEM product(s) that it meets or exceeds OEM specs. then the manufacture must supply their product to you for free. Oil, Spark plugs, drive belts, etc. etc. and not just for snowmobiles but all things, cars, trucks, ATV's, SXS's, etc.
If I didnt run Polaris oil I would use either Interceptor or Mystic oil. I've had good results with both of them.Just run Amsoil Interceptor instead of Extreme.
Very good article. Same info as I've researched and posted. There will always be skeptics who think they know more than the manufacturer. If any oil that claimed to meet the supposed standards was okay, nobody would buy the expensive stuff and the manufacturer would simply put their label on the cheap stuff. This is just common sense.Correct, if the OEM said that, then they would have to provide free oil, so they do not say that for obvious reasons.
Klotz oil does not meet Polaris, doo, or Cats oil spec. Reason is the OEM’s have their own secret specs and Klotz does not know what those specs are. It’s as simple as Polaris might spec VES Gold to be gold in color so it has to meet that spec and Klotz does not. Klotz can put on the bottle they meet OEM spec but what OEM is that for?
This here explains it better: https://www.snowtechmagazine.com/snowmobile-oil-certifications/
I darn near earned a degree of some sort researching oils... there are many good choices. I have to say I was very impressed with what the Mystik JT4 full synthetic snowmobile oil and its content vs several without a doubt proven and expensive other brands! I have not used it yet myself. I’ve used amsoil interceptor for yrs also with no problems at all. Only observation with it was it did have exhaust valves gummed up more than I’d like to see but never a running problem due to it. I hear the VES Polaris oil really is hard on the the valves too.. many very safe choices but know the ratings snowmobile manufacturers require and your fine.If I didnt run Polaris oil I would use either Interceptor or Mystic oil. I've had good results with both of them.
That's internet BS IMO. I've used VES oil in both my 2015 Pro-S 800 HO for 4700 miles and in my 2019 850 XC for 1800 miles. Never had to clean valves. My riding buddies have similar sleds and use VES. They also haven't had to clean their valves any don't have valve issues as well.I darn near earned a degree of some sort researching oils... there are many good choices. I have to say I was very impressed with what the Mystik JT4 full synthetic snowmobile oil and its content vs several without a doubt proven and expensive other brands! I have not used it yet myself. I’ve used amsoil interceptor for yrs also with no problems at all. Only observation with it was it did have exhaust valves gummed up more than I’d like to see but never a running problem due to it. I hear the VES Polaris oil really is hard on the the valves too.. many very safe choices but know the ratings snowmobile manufacturers require and your fine.
That’s truly wonderful your having great success with the oil, great to hear! I have nothing against the stuff. I just have also seen first hand a valve cleaning ceremony performed on a couple of newer sleds with some pretty thick build up with the VES... lots of variables possible.. oil volume? I have sleds with 8000 miles on one set of Hyfax too.. many don’t get that ?That's internet BS IMO. I've used VES oil in both my 2015 Pro-S 800 HO for 4700 miles and in my 2019 850 XC for 1800 miles. Never had to clean valves. My riding buddies have similar sleds and use VES. They also haven't had to clean their valves any don't have valve issues as well.
