I just got done rebuilding my engine and put about 9 miles on the sled so far. Pre-mix in the tank of 50:1(it's whatever it should be. I forget exactly. Maybe it was 100:1). No WOT runs, plenty of warm-up time, all that good stuff. I popped off the exhaust and took a peek and it inspired me to pull off the y-pipe. This is my original cylinder that I had honed with brand new rings and a brand new piston. The other cylinder is from Millenium Tech and looks perfect. How does all this look? Normal? The oil is down from where it started at so I can only assume the pump is working so far with only this few of miles. I can't catch my nail on any of the marks so I know that's a plus. But should the piston and cylinder have these vertical marks already? Should I just keep on riding it and checking it every 25/50/etc miles for the first XXX miles?
Sorry if I'm panicking but I can't afford another full rebuild...
edit: could it be my power valve rubbing on the piston?
