1 - 12 of 12 Posts
Banned
2021 Gade XRS 900T
Allright I know I should post this in the XFire forum but there's more activity and opinions here. Anyhow I picked up my XFire 1000 on the 15th and brought it up to my place in northern WI on the 16th. I put it on my lift and ran it up to normal operating temp and for 2 miles on the odometer. Looked it over really well and found a nut and a muffler spring in the bottom of the pan, no big deal everything else looks good, so far. I get up here last night and I'm in the garage looking it over some more and see some black soot on top of the Y-Pipe on the PTO side. I wiped it off and there appears to be a small pin hole were the welds come together. So based on the facts that I will be putting on a D&D Y-Pipe once broke in and probobly never use the stock one again, but I paid moocho $$,$$$.$$ for this bad boy and it all should be right, right from the factory.
Based on that do you think I should call my dealer and have the stock Y-Pipe replaced? I don't think it will affect performance, or will it? Maybe run a bit leaner with the pinhole???
Banned
2021 Gade XRS 900T
Tell the dealer and if there is a long wait and you have snow, weld it up yourself so you can finally ride the thing.[/b]
Thats my concern. I'll either have to hall it back 150 miles to prove to Cat there's a pin hole then wait 4 weeks to get a new one. And in the meantime northern WI/UP will get the motherload of snow and I won't be able to use it. I'm not going to weld because it would probably void the warranty. I also keep my truck up north here and go back and forth in my car to save on gas$$$$
Anyone think it would run lean with the pin hole???? I'm thinking not, it's a very small pin hole
Anyone think it would run lean with the pin hole???? I'm thinking not, it's a very small pin hole[/b]
Small hole can turn into a big hole I would call dealer tell them whats going on and let them tell you what to do :div20:
Banned
2021 Gade XRS 900T
Discussion Starter · #11 ·
Called my dealer a couple hours ago he checked Cat on line for Y-Pipe availability and said he would have a new one in 3-4 days, so in it goes. He said that he's seen this over the years with some of the Firecats. Also said it's not going to hurt anything if I run it with the pin hole just going to piss some black soot. Ya I could weld it up or patch it with epxoy, but it's the principle here Cat needs to know so they can inform thier supplier.
Why do you think you need to break it in with the stock Y pipe?
Take it off and drop a bead on it. Too much drama taking it back to the dealer. Chances are thats all they are going to do for a pin hole anyways.
IMO
1 - 12 of 12 Posts
