1 - 14 of 14 Posts
Installed speedwerx1000 kit today. Idle pressure is 46PSI on a 2005 F6. I havent had a chance to test at WOT( 1 yr. old sleeping) but the idle pressure doesnt drop when you decrease the fuel flow. Why would it stay the same at idle and is this suppose to work this way? Does 46 seem high? I've heard it may drop some at WOT but it appears to be a little high and should benefit from the PAC. I believe its hooked up right. From fuel tank the reducer comes first then the guage then out to fuel rail. Its a under the hood mount. Any help would be appreciated.
Sounds like its installed correctly. Not sure about PSI for F6 but my F7 is about 45-46 at idle and drops to about 43 at WOT.
PSI drop @ WOT
dito. only drops at wot because the motor is calling for more fuel than the restrictor valve is letting by therefore you see a drop in pressure after the restrictor valve eliminating the rich top end. don't go too lean for trail use though. have fun and good luck
Has nothing to do with the restrictor...FP would drop w/out the restrictor
Funny, because mine didn't drop. :dunno: Maybe 1 psi @ WOT
G
a commercially available gauge might vary + or - 10% from actual, so don't get nervous about a high or low reading based up on what a cheap gauge tells you. Accurate, calibrated lab guages cost 10x as much, we use them here for all critical applications.
Jim, I'm not doubting your test gauges are more accurate but +/- 10% on a commercial gauge is not correct. Most of the gauges are rated 2/3/2 meaning that on a 60 psi gauge the 0-20 psi range can vary by +/- 0.4psi max, 20-40 by +/- 1.2 psi from nominal and 40-60 by +/- 1.2 psi.
Actual pressure for an EFI F series is supposed to be between 42 and 44 lbs using a quality guage. Fuel pressure will not drop on a stock fuel system from idle to W.O.T. because the regulator senses the need and lets more fuel volume through to keep pressure. A reducer system makes the pressure drop disappear to the Stock regulator, because it is metering the flow inline.
<div align="right">index.php?act=findpost&pid=941715
I dissagree . I have installed a guage on my sled, and fuel pressure most certainly does change as the throttle is moved. as the injectors open longer for the larger throttle opening the fuel flow increases and pressure DOES drop vissibly on an inline fuel pressure guage.
2022 XCR 850 136 still waitng for khaos boost
<div align="right">index.php?act=findpost&pid=943183
:div20: :div20:
I have a digital LED guage and my pressure at idle is 47 psi. The pressure doesn't start to drop at idle until the PAC is almost completly closed.
:flag_canada:
1 - 14 of 14 Posts
