I hit a rock tearing off exhaust outlet plate leaving a big opening in the belly pan on our last ride On a 2018 6000. We continued to ride that day with no issues but late in the day the trails deteriorated with the 50 degree temps causing slush to get packed around oil pump and exhaust. I got the code P1003 to show up on my gauge and eventually the motor went into limp mode and had to be towed to where we were staying. The motor is still getting oil and i am guessing the code come up because of the slush and water causing a short. Does a dealer have to clear this code to get it out of limp mode? Or how can I get this code cleared myself? Wire from oil pump to wiring harness is in perfect condition with no rub throughs.
edit to add
I replied to this post below after I brought sled to dealer
Thanks
edit to add
Thanks
