My 07 iq keeps overheating. When i feel the back tunnel coolers they are cold but the front cooler is overly hot. Does anyone have a solution to my problem??
Jack up the front (higher the better) and run it. It might help to create some system pressure by blowing in the overflow tube. Last resort you can crack the rear hose clamps to let the air out.
Jack up the front (higher the better) and run it. It might help to create some system pressure by blowing in the overflow tube. Last resort you can crack the rear hose clamps to let the air out.[/b]
THANKS A BUNCH IT DID THE TRICK
