I have an 04 sabre cat 700 .I went in the trailer today to grab something and I noticed 2 stroke oil all over the floor of my trailer, Ihave a mat and it was kind of sitting in the grooves of the mat.I think it is leaking out of the lower belly pan above the front track drivers and then dripping down through the track. I think this whole problem started when they changed my sending unit. I dont think it is sealed properly.Has anyone had any issues with the oil tanks cracking??? I dont think it is cracked ,but everytime I wipe off the top of the oil tank, it seems to be wet with oil down the road.Also. is it bad to have your track get 2 stroke oil on it??? also the idler wheels have some oil on them.Sometimes I notice the oil leaks more or less depending on the angle of the trailer.
thanks
2018 Sidewinder LTX/LE 50th
My wife's 04 F6 oil tank split at the seam of the censor neck. After the dealer put in a new tank with the new censor I put a ziptie around the neck to give it more strength.
