I just came back from a short lake ride today. I went 40 miles, used 4 gallons and 7.5 oz of oil==68:1. This is after I adjusted the oil pump by 4 turnss.. Rob do you think this is a safe ratio? Or should I crank her up a few more turns?
I'd say a mixture of both, I definetly did a lot of speed runs to see where my clutches were pulling before I install that clutch kit. I was topping out around 7900. Max recall showed 8100, but that was on take off. The lake was well packed today. I ran out of room every run and would hit around 108 before letting off. Will that kit of yours drop my rpms to much? I think it's running perfect right now, other than just getting to the end result a little quicker.
