so basically when you get it back from the update for the oil pump either you ride it wideopen or it sucks cause it loads up right???and also people that have had the updates how far did they turn it up
Mine was updated last week and it seems to be fine. I do not have a baseline to compare to as the sled only had 15 miles on it when I had it adjusted. It does not smoke excessively. It does not have a bog. It runs just fine.
Where is your bog. I have always had a slight bog in around midrange. It would only happen once in a while. I posted about it and alot of people said they were having the same problem, But nobody seemed to know what it was.
Mine does not have a bog.
