i did the bulletin, and now i am running way rich, so i took the linkage back off, just wondering how many threads you guys are seeing when you are done, or at what thread are you running the correct ratio, i have 6 threads showing with the nut on, what do you people show??
When I adjusted mine, I originally had around 6 threads, I adjusted it 4 turns and that brought me from 80:1 to 70:1. I may turn it down another couple of turns in order to lower the ratio even more. Don't go by the ammount of threads showing since this is where the problem exists (everyone is different) You need to figure out what ratio your running at.
