I have something for every one to try for a comparision. With the engine NOT running, grab the throttle lever and hold it in the wide open position, then with your other hand grab the oil pump linkage rod and pull straight up till your oil pump opens fully, check to see how play you have left before oil pump is all the way open. Mine has about an 1/8 inch of play left. Just kinda of a quick test to see how far your pump is opening. B)
but that really doesn't tell you anything.. Different pumps deliver different flows at the same settings.
Figure YOUR individual ratio. That is the only way to do it.
