Found injection oil in belly pan when checking out F7. Looked closer and found mag side oil line was off of oil pump. Replaced and took a short drive and line was off again.Took sled to dealer and found that the line was plugged on the end with epoxy. Seems to have happened when the line was inserted into the carb rubber boot and filled with epoxy sealent. Other than this just can't get enough F7 fun.
