1 - 14 of 14 Posts
What tools are required to install this kit into a 700 Sabercat.
Any help would be appreciated.
LBD
Originally posted by firecatfever@Oct 17 2005, 03:14 PM
What year?    2005 or newer will be a bit more complicated due to the Diamond Drive.
<div align="right">index.php?act=findpost&pid=935105
This is a 2005 Sabercat. No diamond drive on Sabercats.
LBD
LBD
<div align="right">index.php?act=findpost&pid=935121
oh, I didn't realize that the sabercats don't have the DD.
The only "special" tool you will need is a Clutch puller to get the primary off. Other than that you will need a half inch wrench to get the secondary off, and apart.
You will need a 1/2" socket to get the primary bolt off, and then use the clutch puller as I mentioned. You will need a Torx bit (forgot what size) to get the primary apart, and to take out the pins that hold the weights in.
Not much to it :div20:
Thanks a lot Firecatfever for the help. I was looking through a sled catalogue and saw a number of different clutch tools and thought maybe I was heading for a large cost for tools as I really want to do this work myself.
LBD
....and actually you don't NEED a clutch puller. Just a torx bit and 1/2" wrench to get the secondary apart. Puller makes it much easier though....tight quarters otherwise.
<div align="right">index.php?act=findpost&pid=935128
[/quote
For the 1/2 inch socket it needs to be a 12 pt. A 6 pt. will not work. (at least on my 2003)
IF you are going to remove the secondary and primary. Get a 14" 3/4" dia threaded rod - 4 nuts and 4 large dia washers. You cna put the readyrod into a vise to use it as a makeshift compressor. It is much easier to disassemble and reassemble the clutches. And safer.
Also DO NOT forget to puit alignment marks on the assemblies prior to dissassembly!!!
Also a small torch to heat the setscrew on the flyweights would be good.
Discussion Starter · #11 ·
Discussion Starter · #13 ·
quote
Because the bolt has a 12pt head on it :div20:
d'oh :banghead:
1 - 14 of 14 Posts
