Installing a 1.5 camoplast intense on girlfriends sled, wanted to go up 1 bottom from 23-39 (original) to 23-40.
From chart says N/R (non recommended) Is that right, should I go to either 22-40 or 23-41
We rarely do high speed riding, mostly playing in fields.
Any suggestions
Any suggestions[/b]
Use the 22/40 that way you can use the stock chain.
23/40 is n/r due to the tight fit. Older stretched chains and perhaps a little grinding on the tensioner it can be made to work though. But I would stay with the 22/40
Mark
22/40 is a good trail sled choice with a 1.5" track , if its studed you amy want more gear.
