1 - 1 of 1 Posts
My sled (2010 assault 800) had the ECU go bad. I replaced it and matched the injector colors. The sled starts up, a little rougher than normal, but will stay running at idle. If I give it any throttle the rpms will come up but as they come back down the sled will die. I can start it again although it usually takes more effort. Maybe it needs the be flashed? Secondly the check engine light is flashing twice. I googled it but could only find a check engine flashing twice for an 05 rmk. The post stated its a water temp sensor fault. Can anyone confirm this for 2010 or provide me with the correct information?
Thanks!
1 - 1 of 1 Posts
