Does anyone know the torque specs on a '94 Wildcat 700 EFI for the exhaust manifold stud that goes into the head as well as the nut that holds the manifold on? With the block being aluminum I don't want to just guess at it. Thanks. :i_need_snow:
Doesn't play well with other
Does anyone know the torque specs on a '94 Wildcat 700 EFI for the exhaust manifold stud that goes into the head as well as the nut that holds the manifold on? With the block being aluminum I don't want to just guess at it. Thanks. :i_need_snow:[/b]
There not that critical, I would imagine some were around 22-28lbs. I would just use a short 1/4in drive ratchet and snug them up good'n tite
Thanks for the info Flash and Flare, I just wanted to make sure they're tight enough without going overboard. The big twin has alot of vibration to it. Thanks again. :thumbsup:
