rebuilt a zr700 today and know there is very little spark, only 2 volts is going into the coil. Is this enough to start or should there be more
i got a stupid question, Did you check the throttle saftey switch on the throttle lever? I had my zr700 (2000 Miles) and a z370 (350 miles) go bad on me. On the 370 it wouldnt start. THe lights came on dim but it wouldnt turn over. You had to pull the rope and play with the throttle lever to get it to start.
Discussion Starter #3
this is for my friend that called me up, I had the same problem w/ my 600 and he knew about it so i would think he checked that. He said there is very little spark so he is thinking its the coil or magneto
