i have a 2001 xcsp 600 and i was wonderin how to paint the hood and cowl on the sled. What is the best paint to use? and what kind of prep do i have to do to get it ready to paint. should i sand and primer the hood and maybe use bonbo? any help would be great
i have a 2001 xcsp 600 and i was wonderin how to paint the hood and cowl on the sled. What is the best paint to use? and what kind of prep do i have to do to get it ready to paint. should i sand and primer the hood and maybe use bonbo? any help would be great[/b]
use any good automotive paint, wash with soap and water first, then a wax and greese remover, BEFORE YOU SAND, plastic body filler[ bondo] will work to fix imperfections prime thease areas ,if you are just changing colors, no need to prime, just seal, then color then clear, sand and buff. if needed.
And use some flex additive to the paint.
