I'm helping a buddy replace his track on his ZR. I need to know where the small washer goes on the front suspension. Does in go on the inside of tunnel or outside the tunnel?
I'm helping a buddy replace his track on his ZR. I need to know where the small washer goes on the front suspension. Does in go on the inside of tunnel or outside the tunnel?[/b]
The should be a washer under the head of the bolt and one under the nut. Usually you put the bolt in from out side in (nut side in the tunnel). The smallest flat washer goes under the head of the bolt. The larger flat washer goes under the nut to keep the spacer on the front arm in place.
Good luck!
Thanks a lot guys!! I thought thats how they went,but there was no mark on the tunnel were the washer goes and I wanted to be safe. :biggrin:
