1 - 8 of 8 Posts
Get a re-programmed cpu, many well placed studs, get the rear and front lowered as much as possible without tying the suspensions down, make some regular (non carbide) wearbars, different weights, springs, helixes, gearing, you will set and ready to go trail stock racing!!
If you are running the trail stock class in MI. or psgdra you can tie the suspension down you just have to maintain 2" of travel in the front and 4" in the rear with the driver on the sled.
Originally posted by ricor2008@Sep 10 2005, 06:22 PM
I want to race grass. I have an F7 carb. What besides lowering it, should I do 2 it?? to race in stock, or mod??
<div align="right">index.php?act=findpost&pid=868991
Consult your jetting chart and conservitivly use your imagination on re-jetting the sled. Then tighten your fuel screws some, and loosen them air screws up some.
What type of studs/track are best used for grass racing??? any successful combinations??
<div align="right">index.php?act=findpost&pid=869141
The best combination is the camoplast speed track with chissel studs, if you can, also weld on "hooker" style plates to the track clips, for screw in chissel studs as well. That is if you not just racing "trail stock" class, but stock class or semi-pro class. If you want to be competitive then you need to run 5.5-5.6 500' times in 700 single pipe. Also, invest in a set of brower timeing systems wireless and find a smooth practice strip if you can. You can get use out of the brower timing system for doing your own ice runs, there not just for grass racing. Good Luck.
1 - 8 of 8 Posts
