1 - 10 of 10 Posts
Doing some work and now have a 03 F6 basically. The early build F6 from what i remeber didn't have the new style weights and pins yet so I'm looking for the weight part numbers and sizes and other clutching specs for all elevations in this sled. I can look up the diagram but it does't show the different elevations just what they came with stock and the part number of the weight I found doesn't show up in the service manuals like most do so any help would be appreciated. All the info would be on the label under the hood on the backside of the gas tank. Thank you in advance.
look under the hood of it. all of my cats in the past have had a sticker with all of the clutching recommendations with part numbers.
Thats what I'm asking someone with a 04 F6 early build to do. I don't actually have one just have a 03 Firecat that has a 600 in it now and need the specs so I can set mine up.
For the EBuild 04 600
0-3000 53gram
3-6000 52gram
6-9000 50gram
9000+ 47gram
This is with a 0-3000 is a yellow/green primary and 3000+ is a yellow/white.
Now 0-3000 is 55/53helix
3-6000 53/51
6000+ straight 49
Red/white secondary spring all elevations.
0-3000 40T 19T gears. 70Pchain.
3000+ 44T 18T gears 72Pchain.
10T drivers 7.94" 136" track. :div20:
0-3000 53gram
3-6000 52gram
6-9000 50gram
9000+  47gram
3-6000 53/51
6000+ straight 49
<div align="right">index.php?act=findpost&pid=915091
those specs are way wrong.. not sure where they came from but the run 60 gram weights in EB F6's
Stock Clutching is 60g weights,yellow/white primary,53/51 helix,red white secondary spring.
Discussion Starter · #8 ·
Donno how would the 600mtncat specs work on a EB F6 completely different engines. Thanks ODS and Fastcat thats exactly the info I was looking for now if you guys could just give me the info for the 9+ as well as the part numbers on the weight for high elevation I would really appreciate it. ODS any luck on that handgaurd mount thanks for the help.
<div align="right">index.php?act=findpost&pid=915136
Also 20/39 gearing with 70P chain - 1" lug track.
I just checked my owners manual for the info, but it wasn't listed. It is listed on the sled however - but unfortunatly mine is in storage... :doh:
Heres what it states under the hood:
up to 5000ft. 19t-40t. gears
5000-9000ft. 56.5 gram weights
9000 and over 53 gram weights and 49* helix
1 - 10 of 10 Posts
