Well I was going to but can't get it to work. I pick my file and hit upload. It then says it is uploading but nothing is actually uploading. Size of pic is about 150k so that should be ok, any suggestions?
And in the meantime how about jetting?
I was at 440, 460, 440 with the needles at 3.5, 4, 3.5. The variflow was set for 5% lean. -10c @ 1800ft. I am not able to get some long pulls on the mains so not sure what they need yet, but leaner. The midrange temps sure get up there though, I can see over 1300 pretty regular, the center can be up to 150 degrees over the others. Max recal has been over 1500 on the center and near 1400 on others. Just some numbers, not worried about them yet.
The plugs are very hard to read, the oil seems to make them dark. Anyone have a suggestion as to a good oil for reading plugs? The wash after 70 miles running in the mid to occasional wot was a little rich but close in the center, mag was rich and the pto was the richest.
I dropped a jet size and will run the variflow at 7.5% reduction and try again, should be reasonably close for needles but gotta check it. Thinking I may drop the pto to 3.25 but?.
72 miles and the tank was on E. Not happy about that part but I was making trail in full stubble fields pretty much the whole time. I hope I can get that a bit better.
