Heading to the Bighorns in a month and looking to gather the parts needed. Riding is at 8000 - 9000 ft. How have you set up your RMK's for this altititude. Temps should be between +5* to +30*.
Jet size
Needle Position
Air Screws
Weights
Primary Spring
Gearing
Secondary Spring
Helix
Thanks for your knowledge!
Jet size
Needle Position
Air Screws
Weights
Primary Spring
Gearing
Secondary Spring
Helix
Thanks for your knowledge![/b]
340-350 for jets. Needle in #2 position. 1 1/2 on air screws. 60 or 62g weights. Almond Round Primary spring. 19/43 gearing with 74P chain. Red/black or black/reb secondary spring. I've personally had good luck with a 64/40/46 helix.
340-350 for jets. Needle in #2 position. 1 1/2 on air screws. 60 or 62g weights. Almond Round Primary spring. 19/43 gearing with 74P chain. Red/black or black/reb secondary spring. I've personally had good luck with a 64/40/46 helix.[/b]
In addition ,my escape came with pink ev springs and 2.0 cutaways . It was delivered for 9000 ft. from tri-city polaris in centerville utah.
To add to my pm, you should change the ves springs as mentioned. You should also have the stainless ves valves. Run yellow springs for about 5-8000ft. with the stainless, #7041704-05, and white above 8000ft. #7041704-???? (don't have the - number).
