gonna order some helix and stuff as i added a 1-1/2" track to a stock 03 700, any sugg. weight 215 naked
I am guessing that your going pwder riding???? so clutching isnt up my alley ( I ride flat land stuff mostly).
duel use gearing I think you should be around 1.75~1.85 to 1 gear ratio...
24/42 = 1.75
23/41 = 1.78
23/42 = 1.82
22/41 = 1.86
no not powder ride, just flat land mostly trail,ditch and pit, the 1inch just goes nowhere its pathetic, i odn't think 1.25 is enough especaillt at 14" anyways the snow gets deep sometimes and i wann go anywhere anytime, maybe 1.25 on a wedge but not a pro-x, just not as easy to get technical with the x maneauver<<??
If your a flatlander / ditch banger thats a differnt story.
140-330 primary spring
10-64 if you have a stock motor, 10-66 if you have 10 hp more then stock. you want your 700 to run about 7950 RPM peak with a stock single pipe.
70-44.46 helix with a red/blue team spring
24/41 gear min .
set the belt side clearance to .015" , it will come in smooth and pull hard all the way up!
