I checked my max rpm and all it ever reads is 4900 exactly. I have checked it a few times and it always reads the same
Any ideas
thanks
Banned
:thumbsup: "RESETTING 2005 DIGITAL SPEEDOMETER/TACHOMETER...............THE FOLLOWING PROCEDURE MUST BE DONE WITH THE ENGINE RUNNING AT IDLE. TO RESET MAXIMUN RPM ON THE DIGITAL TACHOMETER, THE DIGITAL TACHOMETER MUST BE SET IN THE METRIC KPH MODE.....ONCE IN THE KPH MODE, PRESS THE TOP BUTTON IN ONCE AND THE SCREEN WILL SWITCH TO RPM MODE. NOW PRESS THE TOP BUTTON IN AND HOLD. THE MAXIMUN RPM WILL APPEAR. TO CLEAR, HOLD THE TOP BUTTON IN; THEN PRESS THE LOWER BUTTON IN UNTIL THE RPM RETURNS TO THE IDLE RPM OF THE ENGINE". TRY IT, IT WORKS.........HAWK!!!
