1 - 11 of 11 Posts
Discussion Starter #1 (Edited)
- - - 2020/11/21 - - -​
MATRYX Adjustments & Maintenance Videos w/ Tools:
These are some of the Matryx snowmobile Maintenance videos that Polaris has created recently. In terms of maintenance, there is NO difference between the 650 and 850 powered Matryx sleds because of their engine size, OTHER than using different drive belts.
Between the Matryx INDY 129/137 sleds (with PRO-CC rear suspension) and the Matryx Switchback Assault (SBA) 146 (with IGX rear suspension), there is a difference in shock/spring factory setup and how they actually work, but maintenance is pretty much the same, except you don't have to check coupling blocks on the Matryx SBA 146.
These video topics start out with ORIENTATION to the sleds, which does a good job of describing different parts and features and showing where they are located on the sled. There is a video for Matryx INDY sleds and a different one for Matryx Switchback Assault (SBA 146). Since they are basically interchangeable other than the ORIENTATION topic, I have some of each, but cover ALL topics.
A section has been added with 4 videos on Suspension Adjustment.
The rest of the topics are in alphabetical order.
The Table of Contents shows the titles of the videos we have, and then after that are the sections for each video. I added notes on tools, supplies and some information not in the video that I felt was important, so you don't have to make notes while watching the video. The actual YOUTUBE link to the video is at the end of each video's section.
--- TABLE OF CONTENTS ---------------------
850 Indy VR1 Orientation - Polaris Snowmobiles 4:24
650 Switchback Assault 146 Orientation - Polaris Snowmobiles 4:23
Polaris Snowmobiles 7S Display Overview - Polaris Snowmobiles 8:42 7SDD Gauge & GPS Features
https://www.youtube.com/watch?v=4-YgaDGQZuo 4:23
Polaris 850 Patriot Sleds Factory Build MY19 - Polaris Snowmobiles 0:50
850 INDY VR1 Battery Removal And Installation - Polaris Snowmobiles 3:31
850 INDY VR1 Chaincase Fluid Replacement - Polaris Snowmobiles 4:13
650 Switchback Assault 146 Drive Belt Deflection Inspection & Adjustment - Polaris Snowmobiles 2:35
650 Switchback Assault 146 Drive Belt Inspection And Replacement - Polaris Snowmobiles 3:11
850 INDY VR1 Drive Chain Tension Adjustment - Polaris Snowmobiles 2:56
2
Polaris Snowmobiles Fuel Type Selection - AXYS & MATRYX 3:13
Polaris Snowmobiles Low Fuel Startup Procedure - Polaris Snowmobiles 2:34
650 Switchback Assault 146 Pre-Ride Inspection - Polaris Snowmobiles 5:01
850 INDY VR1 Ski Skag Replacement - Polaris Snowmobiles 1:48
850 INDY VR1 Spark Plug Inspection And Replacement - Polaris Snowmobiles 2:58
650 Switchback Assault 146 Track Inspection And Tension Adjustment - Polaris Snowmobiles 3:19
SUSPENSION ADJUSTMENT for RIDE & HANDLING​
Understanding Suspension Adjustments: Suspension Adjustment Points - Polaris Snowmobiles 3:14
Understanding Suspension Adjustment: Handling and Cornering - Polaris Snowmobiles 5:10
Understanding Suspension Adjustment: Ride Comfort - Polaris Snowmobiles 3:47
Understanding Suspension Adjustment: Perfect Ride - Polaris Snowmobiles 2:26
--- LINKS TO VIDEOS ----------------------------
Good Orientation, Terminology and some Easter Eggs from Polaris!
A few grease fittings 7080424, too.
@1:00 Headlight Aim Adjustment lower/higher
@1:04 NOT an overflow bottle. A coolant bottle, under pressure
..... the thermostat is located in the bottom to feed coolers
@1:17 Battery Charging port w/red cap between brake caliper and console
@2:10 USB plug only with 7SDD inside glovebox
@2:29 the transparent brake reservoir on NEW master cylinder
@2:31 NEW left hand control buttons.
@3:15 NEW seat toolless removal, underseat storage bin
..... Quarter turn knob from underneath, behind the bin
@3:23 PRO-CC (INDY 129/137) rear suspension & 3 grease fittings
. 1 zerk @bottom of shock pivot arm for front of RTS shock
@3:41 Rear pivot arm/Scissors link mounted on shaft between rails
. 1 zerk @bottom of link, 1 zerk @Top/rear torque arm end
https://www.youtube.com/watch?v=__QDluw3IFc 4:24
@0:56 Headlight Aim Adjustment lower/higher
@1:02 NOT an overflow bottle. A coolant bottle, under pressure
@1:11 Battery Charging port w/red cap between brake caliper and console
@2:00 USB plug (?only with 7SDD?) inside glovebox
@2:20 the transparent brake reservoir on NEW master cylinder
@2:24 NEW left hand control buttons.
@3:11 NEW seat toolless removal, underseat storage bin
@3:23 IGX (SBA 146) rear suspension & 4 grease fittings
. 1 zerk @ top of pivot bracket for front of RTS shock
. 1 zerk @ Rear torque arm tunnel mounting shaft
https://www.youtube.com/watch?v=74GygAtp_J4 4:23
Lots of tools & robots & lifts & craftsmen/women, etc.
https://www.youtube.com/watch?v=Kup1F3B0uFQ 0:50
Battery is 4013045 Yuasa YTX20CH 20AH 270CCA sealed.
. Charge at up to 1.8 amps for 5-10 hours
10mm socket (terminal bolts), extension
T40 Torx Bit
Ratchet handle
torque wrench
Tuflok Pin puller/ large sidecutters/ flat screwdriver
dielectric grease / petroleum jelly
Safety Glasses, Gloves, Shop Rags, Parts pan
Battery Terminal bolts: 10mm socket, 3 ftlb / 4 Nm
https://www.youtube.com/watch?v=tQCvnECeGhs 3:31
6mm allen bit & extension
ratchet handles
torque wrench
Synthetic ChainCase oil about 10.5 oz.
Fluid filler funnel/ Syringe/ cone top bottle
Safety Glasses, Gloves, Shop Rags, Pan for parts
... Suction Method
Fluid suction device
Container for oil removed
... Front Cover loosen Method
T40 Torx bit
10mm Socket
Drain Pan
Prying Tool
Battery terminal & bracket removal/replace tools
Chaincase cover capscrews: 10mm socket, 11 ftlb / 15 Nm
Under Fender Screws: T40 bit, 3 ftlb / 4 Nm
Chaincase fill plug: 6mm allen, 4 ftlb / 6 Nm
https://www.youtube.com/watch?v=OrtdSgJZIU8 4:13
650 uses 3211165 drive belt
850 uses 3211215 drive belt
1/8" Allen Bit (preferred, can use Allen wrench)
7/16" Wrench
7/16" socket
Ratchet handle, extension
Torque Wrench
Straight Edge (Flat Bar, not much room)
. 1/4"/6mm Thick, 1"/25mm Wide, 11"/28cm Long
Clutch Spreader tool (L bolt on sled)
Belt Deflection goal is 1 1/4" / 3.2 cm
Jam Nut: 7/16" socket, 12 ftlb / 16 Nm
@1:15 It might be easier for owners, to advise:
Turn the set screw clockwise to increase belt deflection.
Turn the set screw counter-clockwise to reduce belt deflection.
Some may not understand the effect of opening or closing the sheaves.
https://www.youtube.com/watch?v=vlSAMzIeCQw 2:35
Clutch Spreader tool (L wrench on sled)
Whenever changing drive belts, belt deflection should be checked.
https://www.youtube.com/watch?v=DcWtwbnyzSw 3:11
T40 Torx Bit
15mm Wrench
15mm Crowfoot Adapter for Jam Nut
Ratchet Handle
Torque Wrench
Tuflok Pin puller/large sidecutters/flat screwdriver
Battery terminal removal tools: 10mm socket, extension
Adjuster Jam Nut: 15mm Crowfoot Adapter, 21 ftlb / 28Nm
https://www.youtube.com/watch?v=bKiDoSluBMA 2:56
NO tools
0:23 for Digital MSG Center Matryx/AXYSP
1:04 for PIDD (Axys)
1:47 for 7SDD Matryx
https://www.youtube.com/watch?v=l7xKRoVVABQ 3:13
Gas Can with minimum 2 gal. fuel
Funnel
Assistant (For tipping Manual Start Sled)
0:20 with Electric Start
1:08 with Manual Start or dead battery
https://www.youtube.com/watch?v=Ic3u9Qx-tFc 2:34
6mm allen bit & extension & ratchet handle
Flashlight to check fluid level in the transparent brake fluid reservoir.
https://www.youtube.com/watch?v=dncnCSX5KmM 5:01
13mm deep socket
ratchet handle w/extension
torque wrench
Lift or support jack for to raise skis 6" or more off ground
Large Screwdriver / Prybar to remove skag
Deadblow hammer or wood block to drive skag into ski
nuts on skag: 13mm deep socket, 7 ftlb / 10 Nm
https://www.youtube.com/watch?v=C2Swnk5uGVo 1:48
Spark Plug Wrench (on snowmobile)
13/16" Crowfoot adapter
Torque Wrench
2 BPR9ES 3022082 spark plugs used on all Matryx 650/850
Spark Plug Gap checking tool 0.027" / 0.7mm
Spark Plug: 13/16" Crowfoot adapter, 18-22 ftlb / 24-30 Nm
https://www.youtube.com/watch?v=lA8FkEy-r34 2:58
shows Matryx 650 VR1 650 White Lightning w/black, red spindles rails
Names and Locations of Adjustment Points
0:27 Clicker adjustment knob on shock reservoirs
0:34 IFS Independent Front Shock/Suspension
0:35 FTS Front Track Shock (Center of sled)
0:38 RTS Rear Track Shock
0:47 Hi-Low speed shock adjustments and effects
1:12 Shock Spring Pre-load adjustment
1:30 Tie Rod affects Ski Alignment, Toe-in/Toe-out
1:48 Ski Spacers. Adjustable for SKS/RMK
1:56 Limiter Strap Adjustment
2:24 Torsion Spring Adjustment weight transfer & ski weight
2:39 Handlebar Settings Tools Required
https://www.youtube.com/watch?v=w5NJuitr-b0 3:14
Weight transfer between front and rear of sled.
OVERSTEER, turns aggressively track slides out, fishtails
... Need to transfer weight from front to back
UNDERSTEER, sled front pushes when attmpting to turn, keeps going straight.
... Need to transfer weight from back to front
DARTING, skis grab ruts in trail and turns in a way that was not intended.
... Check for proper toeout, if ok, then increase FTS spring preload
SKI LIFT, Skis lift off the ground during acceleration resulting in loss of steering control
... Decrease FTS spring preload
... Decrease IFS spring preload
... Turn up Rear Coupling blocks to resist weight transfer to rear
https://www.youtube.com/watch?v=D7RF-RPbkOk 5:10
DISCOMFORT FELT on HANDLEBARS
... adjustment to IFS shocks
DISCOMFORT FELT on ANKLES
... adjustment to FTS
DISCOMFORT FELT on BACK
... adjustment to RTS
CHATTER: Excessive harshness from the suspension when traveling over rough terrain
BOTTOM OUT: Where the suspension compresses fully and reaches it's end stop
WHOOPS/MOGULS: A series of smaller hills in succession that toss the rider around.
https://www.youtube.com/watch?v=0lebvRBeBgQ 3:47
Before riding/tuning, make sure suspension is set to factory specs.
First, Ride the sled to get a baseline on ride and handling.
. Consider how the sled handles at your preferred speed?
... Oversteer, Understeer, Darting ?
. Does the sled handle corners like you were expecting?
. Does the back of sled slide out when turning?
. How does the sled react to your acceleration habits?
... Does the front end lift too much when taking off?
... Does the track seem to spin too easily?
. Are you reaching your desired comfort level?
. Does the ride feel harsh or too soft?
UNDERSTAND, there will be tradeoffs / give and take, to any adjustments you make.
https://www.youtube.com/watch?v=uAeVdizY5b4 2:26
Discussion Starter #4 (Edited)
Thanks for the kind words, gentlemen.
I tuned the post up a little, and made it a little more consistent in format. If anyone sees some mistakes or becomes aware of any additional information, just post it on this thread, and I will work it into post #1 when I can.
  • Like
Reactions: Doug S
Discussion Starter #5
Made some changes to the above post#1
  • added Low Fuel Startup Procedure video
Discussion Starter #6
Made some changes to the above post#1]
  • added Fuel Type Selection Axys & Matryx video
  • added Added Assembly Line 3 minutes video
Discussion Starter #7
  • A section has been added with 4 videos on Suspension Adjustment.
How do you get access to the videos? A few of them say the video is private and I need to be granted access. Specifically the build video "Polaris MY11 Switchback Assault 144 Assembly Line"
2021 Polaris VR1 650
Go to the Polaris snowmobile website, create a account if you have not done so. Under "vehicle 101" you will see a DIY video tab.
Discussion Starter #10
  • Added video for 7SDD gauge & GPS
  • replaced MY11 assembly line video with MY19 video
  • . Due to security change
I'm sorry this happened, I must not have been signed on correctly when I tested it.
Discussion Starter #11
Added Table of Contents to Suspension Adjustment Points video
1 - 11 of 11 Posts
