MATRYX Engine & Chassis parts specs & differences
1 reading
18K views 22 replies 8 participants last post by  ExcursionPSD
#1 · (Edited)
Linked from FAQ
as of May 2, 2022​
Polaris Matryx Engine & Chassis Differences
MY21-19 650 & 850 ENGINE SPECS
This table shows changes and similarities for the Matryx 650/850 engine parts and the MY21, MY20, MY19 850 Patriot Axys flatland engines. It is not yet complete, some of the parts books are in conflict.
Differences for a component are shown by the symbol: <<
OR by the symbol * when there are more than 2 columns.
ComponentMY21-22
Matryx
650 Patriot
MY21-22
Matryx
Flatland
850 Patriot
MY21-22 AXYS
850 Patriot
Notes _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Operating
RPM
8250 +-1508250 +-1508250 +0 /-150
Idle RPM1600 +-2001800 +-200 *1800 +/- 150
Engagement
RPM
38003000 *
Thermostat
Opening temp
80-87F /
26.6-30.6C
80-87F /
26.6-30.6C
100F/ 49C
ELECTRICAL
. ECU Computer4019066 <<4019066 <<4018714MY20:4018714
MY19:4016652
Heater- Grip2415119 LH2415119 LH2414329 LH <<<--MY19-20 flatland
. RH heater2415120 RH2415120 RH2414328 LH <<<--MY19-20 flatland
Alternator
output
500 watts500 watts500 watts<--MY19-20 flatland
ENGINE,COOLANT
Coolant temp
Sensor
241575624157562415756MY20:4010644
MY19:2208359
Coolant tank
w/thermostat
124143912414391241439MY19-20:
1241177
ENGINE,CYLINDERS
Cylinder, bore:3023607 74.8mm <<3023433 84mm3023433 84mm<--MY19-20
Gasket, Base581450558145055814505<--MY19-20
Cyl Head,
bore:
3023610 74.8mm <<3023282 84mm3023282 84mm<--MY19-20
Head oring,
bore:
5411044 74.8mm <<5411359 84mm5411359 84mm<--MY19-20
displacement650 cc <<840 cc840 cc<--MY19-20
ENGINE,EXHAUST
Gasket, Exh.
Manifold
Y pipe Exh.
Manifold
1263266-029 <<1263034-0291263034-029<--MY19-20
Exh. Socket
donut seal
3610046 <<36102993610299<--MY19-20
ASM Tuned
Pipe x50
1263307 <<12630671263067<--MY19-20
Resonator
Socket donut
5211688 <<36100473610047<--MY19-20
Resonator/
Muffler
1263068-0291263068-0291263068-029<--MY19-20
EGT Sensor24016024 two4016024 two4016024 two<--MY19-20
VES ===
ENGINE,EXHAUST VALVE
& ACTUATOR
Cable Push/Pull708229170822917082291<--MY19-20
Cable
Movement
0.59-0.69"samesamesame
Exh. Valve
Bushing pair
220893022089302208930N/A
Tiebar514353951435395143539MY19-20: 5140921
EV Base ASM120870112087011208701<--MY19-20
Guillotine,
Upper
5142851 <<51422165142216<--MY19-20
Guillotine,
Lower
5142852 <<51409235140923<--MY19-20
Actuator, EV
xxx-Smart
4018736
NONsmart *
4018736
NONsmart *
4016933
Smart
<--MY19-20
ENGINE,MOUNTING
Mount Mag
Front/Rear
302361230236123023612MY20:3023612
MY19:3023273
Mount PTO
Front
302353430235343023534<--MY19-20
Mount PTO
Rear
302345330234533023453<--MY19-20
ENGINE,PISTON/
CRANKSHAFT
Piston, bore:2208741 74.8mm <<2208205 84mm2208205 84mm<--MY20
Piston Rings,
bore:
2208749 74.8mm <<2207821 84mm2207821 84mm<--MY19-20
Connecting
Rod Asm
220879222087922208792N/A separately
PTO roller
bearing
351515735151573515157MY20:3515157
MY19:3515054
Crankshaft
balanced x50
2208740
650 <<
2208745 8502208745 850MY20:2208235
MY19:2207818
CrankCase220823622082362208236<--MY19-20
ENGINE,REED VALVE & TB
Adaptor
Throttle Body
Adaptor
5417450 *5417450 *1205609<--MY19-20
ASM Reed
Valve
1206267 *1202625 **1205639<--MY19-20
Reed Petals Kit2208584 <<22079482207948<--MY19-20
ENGINE,WATER PUMP
.WaterPump
Housing
563458456345845634584MY19-20:
5634074
FUEL SYSTEM,FUEL TANK ASM
Pump & Float,
sock ASM
2208147 * 6502208146 ** 8502205700<--MY19-20
Fuel Pressure42 to 49 psi
292 to 336 kPa
57 to 62.5 psi *
393 to 431kPa
PFA sock only220814522081452205699 *<--MY19-20
FUEL SYSTEM,RAIL, LINES &
Throttle Body
Fuel Line
Supply ASM
252220325222032521791 <<<--MY19-20
Fuel Line Ret
w/Sensor
252220425222042521792 <<<--MY19-20
Fuel Rail,
ASM
252218425221842522184<--MY20,
MY19:2521918
Injector w/lead401753640175364017536<--MY19-20
Throttle Body1206131 <<12058751205875<--MY19-20
.TB size50mm50mm50mm
MATRYX Suspension and other Parts Specs
This table shows changes and similarities for the non-engine non-powertrain parts for the MATRYX INDY VR1, Launch Edition, & SBA 146 sleds. The shocks & coil spring table is by itself, because the ONLY difference between INDY VR1 trim, and INDY Launch Edition trim IS the shocks & coil over springs. And the 7SDD display.
Meaning of Color suffix numbers on Polaris Parts:
-067 Gloss Black
-070 Black
-133 Bright White
-266 Cruiser Black
-293 Indy Red
-309 Natural (aluminum)
-329 Black (electrocoated)
-402 Turbo (bright) silver
-458 Matte Black
-599 White Lightning
-630 Lime Squeeze
-647 Orange Burst
-666 Black
-689 Velocity (med.) Blue
-737 Sky (light) blue
-751 Polaris Blue
-784 Plum Crazy (purple)
-795 Polaris Blue (Non-Metallic)
-801 Neon (lime-yellow)
-804 Stealth Gray
-887 Teal
ComponentINDY VR1, &
Launch Edition
SBA 146chg _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Front Travel9.3"9.5"<<
IFS spindle,1824939-067 LH1824939-067 LH
,Matryx Web1824940-067 RH1824940-067 RH
sway bar5251975-3295251975-329
. diameter13.5mm 0.531"13.5mm 0.531"
. 531 bushing
half (use 4)
54375405437540
OPTION forSidehilling
sway bar OPT5252629-3295252629-329
. diameter11.1mm 0.438"11.1mm 0.438"
. 438 bushing
half (use 4)
54378315437831
handlebar53402865340286Matryx only
25mm Alum.
Riser/spacer51430495143421<<
. Height60mm 2.36"85mm 3.34"<<
steer post1825068-3291825068-329
MATRYX Shocks & Coil Over Springs Specs
ComponentINDY VR1MY22
INDY XCR
128/136
SBA 146INDY Launch Edition _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
IFS SHOCK7045432 ***7045773 **7045462 *7045460
WE VelocityWE Velocity Hi/LoWE VelocityWE Piggyback
1.75" Body2" Body *2" Body *Force 1.75"
Extend Length17.3017.3017.3017.30
Collapse Leng.11.4511.4511.4511.45
Stroke5.855.855.855.85
IFP depth2.002.002.002.00
PSI200 psi150 psi200 psi200 psi
Clicker SetFromFullHardCounter-Clock
. IFS clicks5 VR16 SBA5 Launch
Preload Stock10.75" Max9.75" Max10.75" Max
Preload Len9.75" Min8.75" Min9.75" Min
. Bridge Oring180102818009981800184 <<NA
. Shaft, chrome1801158 ***1801086 **1801166 *1801149
. Shaft,
dimensions
5/8" dia x 8.65L ***5/8" dia x
8.65L **
5/8" dia x 8.965L *1/2" dia x 8.6L
. Coil Spring7043732-4587045298-
458 <<
7045298-458 <<7043732-458
. Spring Rating80# matte black.306X10
100# 2" *
.306x10
100# 2" *
80# matte black
FTS SHOCK7045430 **7045771 ***7045433 *7045461
WE Piggyback 2.0"WE Piggyback
2.0" HiLo
1.75" <<
Extend Length12.9512.9512.9512.95
Collapse Length8.958.9468.958.95
Stroke4.125 ??4.125 ??4.125 ??4.125 ??
IFP depth1.751.751.751.50 <<
PSI150 psi150 psi150 psi200 psi
Clicker SetFromFull HardCounter-Clock
. FTS clicks5 VR16 SBA5 Launch
Preload Stock2.25" Max1.75" Min&Max1.62" Max
Preload Len1.75" Minx1.38" Min
Component
INDY VR1
MY22
INDY XCR
128/136
SBA 146
Shock
body blk
1800775180077518007751.75" x5.96L <<
. Shaft, chrome1800774180077418007741801171 <<
. Length5/8" dia x ?5/8" dia x ?5/8" dia x ?1/2" dia x 6.875L
. Adjuster,
spring
1801153 **1801162 *1801162 *1800465
. Coil Spring7045203-458 **7045374-458 *7045374-458 *7043957-458
80/250# x 8.0" 2" **90/280# x8.1" 2"90/280# x8.1" 2" *280# 1.75"
RTS SHOCK7045431 ***7045772 **7045686 *7045465
WE Velocity 1.75"WE Velocity
2.00" HiLo
WE Velocity 1.75"WE Velocity 1.75"
Piggyback NeedlePiggyback NeedlePiggyback NeedlePiggyback
NO needle
Extend Length19.2819.2819.2819.28
Collapse Leng.13.4813.4813.4813.48
Stroke5.805.805.805.80
IFP depth2.252.02.252.25
. RTS clicks6 VR16 SBA5 Launch
. Bridge ID size1.75"1801008
2.0"
1.75"1.75"
. Bridge Oring18010281800863 2.0"18010281801028
. Shock
body blk
1801023?1801023?
. Shaft, chrome180102518012121801163 *1802028
.Shaft,
dimensions
5/8" dia x 9.1L5/8" dia x ?5/8" dia x10.35L *1/2" dia x 8.6L
MATRYX Torsion Springs and other Parts Specs
Launch Edition
REAR TORSION
SPRINGS
.Rider Pounds
STD 140-260
7045190-329 (LH)
7045191-329 (RH)
7041629-329 (LH)
7041630-329 (RH)
. stock.359S,80,11#.359/77<<
LD upto18028849732884976<<
, LH/RH kit.347.347/77<<
HD 220-35028849742884977<<
, LH/RH kit.375S,80,13#.375/77<<
Xtra HD 310up2884975N/A
, LH/RH kit.375S,70,13#
BRAKES,BRAKE SYSTEM
Master cyl
ASM
22084042208404
. only MatryxStealth MatryxStealth Matryx
Brake Caliper,22055012205501
Pistons&padMY15-21MY15-21
Brake Rotor22053732205373
. Used onMY15-21MY15-21
DRIVETRAIN,CHAINCASE
pressed intochaincase
on Driveshaft
and Jackshaft
. Bearing3514309 qty(2)3514309 qty(2)
SAE#6205 2RS6205 2RS
IDxODxWidth25mmx52x1525mmx52x15
. Seal3610030 qty(2)3610030 qty(2)
pressed intocovercover
. Bearing3514643 qty(1)3514643 qty(1)
SAE#6905 2RS6905 2RS
IDxODxWidth25mmx42x925mmx42x9
. Seal3610030 qty(1)3610030 qty(1)
DRIVETRAIN,
CLUTCH,
SECONDARY
Drive Belt #32111653211215 *different belt
Belt Width1.46"1.47" *0.01" different
Side Angle26 deg.28 deg. *2 deg. different
Circumference45.16"45.16"
Ctr Distance10.625"10.625"
DRIVETRAIN,JACKSHAFT&
DRIVESHAFT
mounted inflangettes
. Bearing3514617 qty(2)3514617 qty(2)
SAE#6205 ???6205 ???
self-aligningouter raceouter race
IDxODxWidth25x52x15,
Spherical
25x52x15,
Spherical
flangette,jack52645955264595
flangette,drive10212391021239
Oring, jack54135635413563
.oring size20.30mmx2.6220.30mmx2.62
REAR
SUSPENSION
Pro-CC coupledIGX uncoupled<<
Rear Travel16.2"16.0"<<
ASM-Rail1544450-067 LH1544456-067 LH<<
.. 137 / 1461544451-067 RH1544457-067 RH<<
ASM-Rail1543909-067 LH-<<
.. 129 /1543910-067 RH-<<
Rail Reinforce
137 & 146
5143395 black5143395 black
. for 129 only->5141475 blk<<
Rail hifax5522117-0705522358-070<<
. Top of,137 Lwt, Blk146 Lwt, Blk<<
. mount edge,5522230-070-<<
. is scalloped129 Lwt, Blk-<<
Bogie Rail
spoked wheel
1590632 (qty8)1590632 (qty8)
. diameter5.62" OD5.62" OD
bearing35151423515142
. SAE #NSK 6004 2RSNSK 6004 2RS
IDxODxWidth20mmx42x1220mmx42x12
Rear Idler
spoke wheel
1590459 (qty3)1590459 (qty4)same as
for MY20
IronDog
. diameter7.25" OD7.25" OD
. IDxODxWidth20mmx42x1220mmx42x12
Carrier wheel1590001 (qty2)1590539 (qty2)<<
. diameter6.38" OD?<<
. Bearing35144453514303<<
.. SAE#NTN 6007 LLU6205 2RS<<
.. IDxODxWidth35mmx62x1425mmx52x15<<
.. Retaining
Ring
77104867718407<<
#3 ·
Changes made to post#1 above.
  • Fixed a couple typos,
  • Completed finding & documenting, the significant changes to the 850 Patriot engine back to MY19,
  • Added listings for the .438 Swaybar & bushings to the Suspension table for folks that need to SIDEHILL,
  • these are the same parts that some took off the AXYS ProX sleds to make them corner better.
#5 ·
Velocity shocks have a Piggyback reservoir that mounts in the middle of the shock, not at one end of the shock. This allows them to have their shocking action change and get much stiffer, when the piston goes past this middle travel mounting point as the shock is compressing. Pull up the online parts, and you will see that the Matryx FTS shock is short, and HAS to mount the Piggyback reservoir at the upper end of the 2" shock body, so that there is room for the spring that goes over the shock. For this reason, it is NOT strictly speaking, a Velocity shock, and the Polaris parts book calls it exactly what I have in the table.
The Clicker knob for adjusting compression dampening is key 14.
2107318
#7 ·
  • Added the Crankcase. Same part# for ALL 650/850 Patriot MY19-MY21
  • Added the Braking System. Only changes are the New Stealth Master Cylinder, only on Matryx
  • Added the Drivetrain bearing, flangettes and seals
  • Added the Rear Suspension rails, hifax, (different for 129,137,146)
  • Added the bogie, rear idler and carrier wheels & bearings part#s
  • Probably added some typos, we'll see.
#8 ·
  • Added rows for fuel lines, fuel rail, fuel pump, fuel sock/pickup
  • Added column for Indy Launch Edition Shocks & Coil Over Springs specs
#9 ·
MATRYX Engine & Chassis parts specs & differences post#1
Changes made to post#1 above:
  • Corrected part number for .431 optional softer sway bar. This is used on XCR & Pro-X sleds for better sidehilling and more compliance if only 1 ski hits a big bump or hole. The sled will lean more on flat turns.
  • Updated some shock specs, still incomplete information in the parts book.
#10 ·
#11 ·
#13 ·
Yes, you are welcome old friend! I just make up whatever isn't easy to find. :)
  • Like
Reactions: cfm and Bontz
#19 ·
#20 ·
#21 ·
#22 ·
#23 · (Edited)
Matryx Liquid 2 Stroke Engine Specs & Information
Component Spec650 Patriot850 Patriot9R Patriot850 Boostnotes .......
Bore mm74.88587.9585
Stroke mm74.074.074.074.0
Displacement650cc840cc899cc840cc
CrankshaftLightweight
MY21-3 LW
MY24-5 650/9R
MY21-3 850
MY24-5 850
Lightweight
MY21-3 LW
MY24-5 650/9R
MY21-3 850
MY24-5 850
2
types​
Flywheelstd weightstd weightLightweight
4080622
std weight
2
types​
Crankcasestd Patriot
2208236
std Patriot
2208236
2209827
has porting
std Patriot
2208236
2
types​
Cylinder head3023610
74.8mm
3023283 85MM,P74,
NOM
3024229-751
88mm Blue
3023976 85MM,4MM Outlet, LBV
4
types​
Fuel Pump Assembly45psi60psi60psi60psi
flatland
RMK
different​
Fuel Injectors2222 + 2
You can see that there are basically 2 types of crankshaft, the Lightweight for 650 and 9R and the standard for the 850's They all have the same stroke and are physically interchangeable. All use the same basic crankcase, but the 9R has some CNC porting to help improve air flow.
Each engine uses a different cylinder head. At this time information about MY25 engines is incomplete, there could be changes for the low elevation 9R and possibly Boost.
