have 04 polaris switchback 600 wont rev over 7000 rpm even without the belt on. new plugs,cleaned ves valves
Its not suppose to rev over 7k with the belt off not that you'd even want to do that. Even on a track stand it won't rev past 7k. Sled needs to be actually ridden to achieve full run rpm.have 04 polaris switchback 600 wont rev over 7000 rpm even without the belt on. new plugs,cleaned ves valves
tried that before hanging it form the ceiling and then without the belt on its like it hits a wall at 7000 anyway i try.Its not suppose to rev over 7k with the belt off not that you'd even want to do that. Even on a track stand it won't rev past 7k. Sled needs to be actually ridden to achieve full run rpm.
You must have a higher mileage sled...haven't seen any bad bellows on 03 600 and later sleds since polaris went to a different material. Those older black rubber ones would tear.had to order bellows nobody had them in town. should be here today
