Lithium Battery?
28K views 55 replies 27 participants last post by  denali1
#1 ·
Being the preseason I’m always looking for ways to tinker(and spend $ 🤪), anyone run an EarthX lithium battery? Looks like very significant weight savings...
N—-
#2 ·
I have run a few different Lithium batteries. They indeed are lighter by a huge margin.
If it is a very cold start in the morning the Lithium doesn't have the same Cold cranking power.
Beyond that I love the Lithium battery option. If I had a Doo without a pull cord I probably wouldn't use a Lithium.
Given Poo has a pull cord on every sled I have no problem making two easy pulls on the occasional very cold morning with my Lithium battery.
#6 ·
Thats what I do. I usually have to pull start it in the morning but then its good for the rest of the day.
#4 · (Edited)
Could be exactly what I'm looking for. Let me know if you find a site online with a good price and the cross reference part number.
If I would have ordered a snow check, I would have skipped the ES, but all the factory choice sleds in the area had it. After my 800 without ES, I was thinking the 650 would be easy.
FirePower HJTX20HQ-FP Featherweight Lithium Battery at Amazon might be worth a try for me.
#5 ·
Go with EarthX ETZ14C. I've had zero issues. The WPS one was not good in the cold.
#16 ·
ETZ14C is specifically designed for snowmobiles and cold starts.
#19 ·
Thanks. I took your advice and will try this one this time. My others were lacking CCA when below 10 degrees on a frozen cold motor in the morning. Never really an issue that bothered me much because on the butt cold mornings I'd pull start it once. Never a problem for the rest of the day. If the ETZ14C Earth X proves to kick ass on the Cold mornings I'll then realluy have something to brag about. It really blows peoples minds when you hand them a stock lead battery to put in one hand and a Lithium for the other. It's a bit hard to believe the difference until your holding both in your hands.
#24 ·
Mine was great last year. Never really saw a Cold Winter to test the toughness but there was never any complaints to speak of either. Hoping this year turns to be a better Winter than last year was? Ordered another for the new 2022 sled that hasn't landed yet this year. Thanks for the advice to try this one. (y)
#28 ·
Yes. Its easier and cheaper for me to lose 10 pounds than it is to buy a battery that saves 3 pounds. Dont get me wrong, I love the idea of new tech, but from a practical standpoint, I may only consider a lithium battery once my stock one gives up.
#32 ·
No question the lithium stuff is more expensive and its pretty hard to justify buying one just for the weight savings alone - though it is much more than 3 lbs lighter. A lithium won't weigh half of what a conventional lead-acid one will. The next advantage is lifespan - the first lithium I bought was for my FST (that OEM battery weight a LOT) and I still have that same lithium battery in the sled 10 years later. Still works as well as when it was new. I put one in my '12 Rush, ran it for the life of that sled, ran it in my '15 Axys for the life of that sled, will be able to put it in the next sled when that comes along. Good lead-acid batteries aren't cheap anymore and if you have to replace a couple of them, you'll have spent just as much as if you just bought a lithium and you'll be able to drop that lithium into your next sled.
